More about diff swap
I may not need to swap the diff if I can replace the output bearings on the side of the diff. I got a bit rough trying to remove the seal and it looks like I messed up the bearing. Trying to pry out the old seal I exposed the side of the bearing and can see the roller bearings and think I messed up the bearing assembly. Is that a job I can do or is one for a specialist? I've looked online and can't find that bearing or instructions on replacing it. I just replaced the flex discs, drive shaft and thought I was about finished replacing the c/v axles when I screwed up. When I'm through kicking myself I will proceed.
