Mercedes 87 300D...Diesel Fuel Leak!!!!
Old Jun 24, 2007 | 11:55 PM
spicybabes's Avatar
Default Mercedes 87 300D...Diesel Fuel Leak!!!!
On the left side of the engine (from drivers seat), the fuel travels through this little clear in-line fuel filter thru a short black small hose that goes into this metal cylinderical gizmo bolted to the side of the block. It has about 4 other small black flexible hoses connected to it with small hose clamps. The white plastic part that the hose from the in-line fuel filter connects to is loose and leaking diesel. Looks like I need to replace this approx 2" long metal fuel dist. thing. Anybody know what it is, what its called, part number and or what it costs? Any special things I need to know to change it out?Can I bypass the"fuel thermostat", how much does it cost and where can I order it?...and if I only change theO-Ring will it work? Thanks much in advance
Old Jun 27, 2007 | 09:36 PM
AMGMercedes's Avatar
Default RE: Mercedes 87 300D...Diesel Fuel Leak!!!!
If it's the diesel thermostat then you can't bypass it or replace o-rings. They cost about $130 if you do it yourself. It's easy, but a pain in the butt because of all those hoses that will leak in the process. Post pics of exactly what it is.
Old Jun 28, 2007 | 02:05 AM
spicybabes's Avatar
Can you tell me if the 300D 87 has "fuel thermostat", becauseeverytime time I called and asked to buy " fuel thermostat" for the car it seems to me those who want to sell there products are ok, but other are telling me that 87 300D MBZ has none, so who I have to believe???
Old Jun 30, 2007 | 04:50 AM
MarkReye1's Avatar
Spicy,
Get the Haynes Repair Manual for you car. I got one, took some searching but sourced one locally. In the index it should have a reference to the fuel thermostat. If not, contact adsit.com and order the Chassis and Engine Manual for your car. Unfortunately, those are 90.00 each, but you do get a 10 percent discount. I got my repro Owner's Manual from them, and it looks sharp.
I suspect, I have a small leak from the engine as well, and I would imagine on my 83 240D I could have the same issue. I checked the oil level, and its fine, and also the oil pressure gauge is at 3 at speed.
Mark
Old Jul 1, 2007 | 01:41 AM
spicybabes's Avatar
Thanks very muchMark the leak has been taking care of, as matter of fact my "fuel thermostat" was never the problem and works veryfine,one offuel line was disconnected that' s all.. but all the mechanics (6)I have seenwanted to changemy thermostat, price rangingfrom $425 to $650. Thanks god my brother in law came to spend some times withus and looked at it and found where the leak was coming from, its amazing to see so many "sharks" ready to take advantage of women+ with a delighful accent (French), anyway thank you so much. THANKS! THANKS!
Old Jul 2, 2007 | 03:28 PM
Johnnyrat's Avatar
Yeah I suggest always posting a Question here before you ever take your mercedes to a shop. Good job on saving money on un-needed repairs!!
Old Jul 3, 2007 | 05:39 PM
They get discount parts and it would take less than a half hour install. Nice to see they're reasonable! [&:]So it was a disconnected line. heh
Old Apr 8, 2009 | 11:31 PM
dieseljake's Avatar
The 87 300D definitely has a fuel thermostat and it most definitely can be repaired and not just replaced. If anyone thinks you can't just replace the o-ring to fix the leak they are crazy. They might not know that the thermostat inside is available, but it is. Repairing the thermostat valve will cost you half or less ($40) of what it costs to replace the whole thing ($130-180).
ABeardedMan
Oct 1, 2014 12:35 PM
seadog
Mar 5, 2011 11:11 PM
spicybabes
Jul 13, 2010 09:36 AM
axm1955
Jan 13, 2007 02:40 PM
Bigeasyherb
Jan 28, 2005 12:57 AM
