Master Cylinder? No Brakes
Master cylinder is leaking in the noisy yellow Benz. : P
This could case loss power in the brokes correct? mabey air in the lines Going to the mother of all junk yards tomorrow, see what i can find. Thanks for the Help! 514,000 miles and counting. |
A brand new master cylinder for your car is $80. from Autohaus AZ.
http://www.autohausaz.com/search/pro...ter%20Cylinder Don't take chances with a used one when a new one is so inexpensive. Also, they only take half an hour to change (if you don't count the time you have to spend bleeding the brakes afterward). |
Thanks for the help,
I think mines fine, just need to get a new gasket for it, i got once yesterday going to go put it soon.... If it doesnt cure the problem, then i will be buying a new one. : ) |
| All times are GMT -5. The time now is 03:45 AM. |
