low speed poor performance
Old May 28, 2007 | 03:18 PM
rsmartin's Avatar
Default low speed poor performance
85 300SD 231,000 - bought with 180,000 in Oct 2005 - used for communting from Tennessee to Maryland and back a few times each month. Just useless FYI!!
Problem is.. at low speeds taking off, it can hardly get out of it's own way especially with A/C - was going to give this to my son when he gets his license but i'm a little worried it is too slow and he'll have no power to get out of trouble if he pulls out in front of someone.
i hooked up a pressure gauge between the switchover valve and the line to the ALDA. when taking off i get 1-3 psi until about 2500 rpm when the pressure starts climbing. at about 3000 rpm i'm getting 7.5 psi. is this right?
i have 84 300SD that seems to have a lot more low end pickup AND you can hear the turbo whistle as you take off. i never hear the turbo on the 85
i get about 27 mpg on the highway going about 70 mph on my 10 hr drives
i've been working at replacing all the little rubber vacuum connectors, i've cleaned my line from the manifold to the switchover valve - it was never plugged up but cleaned it out anyway[/align][/align]both fuel filters were replaced in late December after performing diesel purge which resulted in NO perceptible performance enhancement. air filter replaced about 6 weeks ago.
i finally broke down and "molested" my ALDA. took the seal off and turned the screw counter clockwise 1/4 turn. made no discernable difference, turned it out 1/2 turn, made no difference other than started smoking on take off so i turned it back in to just a 1/4 turn
any comments? anything i should check to help figure this out?[/align]
jabbottwku
Sep 24, 2012 12:26 PM
ZigyraT
Jul 4, 2007 12:32 PM
hawke
Jan 11, 2006 11:15 AM
SLK320Chic
Sep 29, 2005 04:44 AM
exdies me
Sep 21, 2005 06:13 PM
