loss of power in 84' 300sd
Old Jul 28, 2006 | 08:33 PM
cfr5555's Avatar
Default loss of power in 84' 300sd
There is 1984 300sd that I am considering, but the owner said the power stops. It will start right up but once and awhile the the power just dies. My guess is the fuel system but i'm not sure. Anybody that can help or give me comments would be greatly appreciated. Thanks
Old Jul 29, 2006 | 09:45 AM
timberfield's Avatar
Default RE: loss of power in 84' 300sd
I'd start with new fuel filters, and check for vaccume leaks.
Old Jul 29, 2006 | 08:42 PM
cfr5555's Avatar
thanks for that, if that is not the problem what else could it be?
Old Jul 30, 2006 | 03:50 PM
duxdevil's Avatar
I have had that problem before, and the problm was that the fuel filters needed replacment. Lucky for me, I had both spares and did them on the side of the interstate and ocntinued on my way. Make sure you do BOTH, but you start wiht the primary, in line filter. You wil need to purge it afterwards. Afterthis, you need to do the secondary, this is a little tougher to do as you need to remove the injectors to purge all the air out or the engine wont start.
Old Aug 9, 2006 | 03:20 PM
Heavyd's Avatar
I had a similar problem with my 1985 300sd, check the air cleaner mine would run good at idle and slow speeds but as soon as you asked the car to perform it would cut out start smoking and barely run.
Old Aug 23, 2006 | 12:21 AM
Mr.47's Avatar
Hi
Maybe This may help.
http://www.restoreusa.com/
problem is i dont know what size to use. They come for 4, 6, and 8 cylinder cans only .
vanhoypc
Nov 9, 2010 05:20 PM
burwellassoc
Jan 11, 2008 09:18 PM
larryms
Feb 3, 2005 12:01 PM
kzr1310
Jul 4, 2004 09:58 AM
papadude
Mar 14, 2004 06:38 PM
