intermittent, slow door locks
Old Dec 23, 2008 | 11:48 PM
tommyk's Avatar
Default intermittent, slow door locks
i have a german 84 300td. nicknamed the molar because it is just big and white! however, door lock working intermittently, slow, or not at all. the problem seems to only happen when the car is cold and not had a long time to run. The right locks will generally unlock themselves after i drive for a bit. the left rear and rear hatch do not. Help! Thanks.
Old Dec 24, 2008 | 08:17 AM
Drrty240D's Avatar
Default RE: intermittent, slow door locks
You probably have a slow vacuum leak somewhere in the system as most of us do. The cold weather shrinks the rubber fittings that connect the plastic vacuum hoses together and makes the problem even more noticeable this time of year.
bdaved
Nov 12, 2011 01:32 AM
gaby7588
May 28, 2008 04:40 PM
mgkaplan
Apr 9, 2004 05:56 PM
mgkaplan
Jan 29, 2004 05:03 PM
cmscott16
Jan 11, 2004 11:16 AM
