How To Tell If Starter Is Going Bad??
I have 82 300d which runs great, but yesterday I couldn't start the car, I changed the battery when I turned the ignition switch to start still no cranking, my dash lights do comes up then I did the test starting on neutral with the headlights on and everything works, but still no crank, then I ask someone to hammer the starter while I was on neutral and then I heard the most beautiful song from my car.
My question is do I have a faulty "starter" do I have to replace it now or maybe wait a little longer?
Thanks in advance
Thanks in advance
First check the neutral saftey switch--they do go out, and will prevent your car from starting. There is a by-pass for the switch located on the upper fender well of the passenger side, just make sure the car is in park or "N". I'm sure there's a thread here that can walk you through it.
sponnerjhon
Apr 6, 2012 04:13 PM
JimMayor007
Sep 21, 2008 01:27 AM
