Help I got a run away
Old May 16, 2006 | 03:52 PM
TennMerc's Avatar
Default Help I got a run away
I had a fuel contamination problem. I pumped it out and got clean fuel. When I finally got it restarted (very hard to restart) I had a full throttle run away. The emergency stop wouldn't stop it. I pulled it loose at the pre filter to stop it. It ran at full roar for about 30 seconds. Wow scary. I talked to the local mechanics they thought somthing (the rack???) might be stuck in the injection pump. Anybody got any ideas?
Bill
Old May 23, 2006 | 11:49 PM
duxdevil's Avatar
Default RE: Help I got a run away
You may have an ignition vacuum pump issue. the problem with MB diesels is they rely heavily on vacuums which arent always reliable.
I once had to use the emergency shut off for this reason b/c the ignition vacuum broke.
Old Jun 1, 2006 | 10:09 PM
carnut's Avatar
I would agree with the stuck rack guess. What was the source of the contamination? gasoline, water, ex girl friends sugar bowl?
idospots
Feb 12, 2013 10:41 AM
funkgab
Aug 3, 2009 08:27 AM
heath111
Jul 18, 2009 12:04 PM
Learick
Jan 22, 2008 10:07 AM
DominicanOps
Nov 13, 2005 10:24 PM
