HELP! '84 W123 300Dt transmission
No forward gears at all - same as neutral, immediate & solid reverse; trans is toast ...
found an engine/tranny unit already removed from host car at a local wrecking yard, BUT I'm not sure it is the proper year. The engine is indeed the 5 cylinder, & the trans connected to it has the following numbers cast / stamped into the exterior of the trans case; I 2185 R1152714501 Can ANYONE say whether this is correct for my car? Just in case, here's the vin for my car; WDBAB33A9EA035883 Considering how rare ANY used Benz trans is & how quickly they are snapped up, I hope for help comes ... ASAP! |
The number you need to know is the one on the side where the Transmission modulator is.
It would also be good to know the Engine Numbers. This is not a recommendation to buy parts there but if you go to the Diesel Giant Web Site he has infor on where to find the Engine and Transmission ID number. There is a website that has what transmission goes into what models but I did not copy the website so you will have to do a search. |
Damn the torpedoes, Full speed ahead!
Given all the BS locally AND on the I-Net, I've decided to personally rebuild the trans I have after having it pulled. I'm asking here for;
a. Affordable procedural manual b. Source for CORRECT parts (on the 1st try?!) c. Notable "Gremlins" which have driven others to drink & insanity d. Any TSBs relating to later/better parts to correct past deficiencies For the record, I'm a retired (USAF trained) Diesel & Hvy Equip / Auto mechanic, but have never been inside a BENZ trans before ... arthritic back ended that line of work YEARS ago ... Thanks to all & Cheers Uncle Tony |
