HELP-300TD won't move more than a foot either way!
So, yesterday, I gently lifted each wheel, and put the snow tires on, one by one. I gingerly used a floor jack, and had the e-brake set.
This afternoon, I started the car, released the e-brake, and put her in Reverse. She moved a few inches, then stopped abruptly! I very gently pulled forward, and had the same result. She'll move about 12" is all - then, well, it's like an iron bar is stuck through one of the U-joints, or something. Thoughts? I was needing it to get to work tomorrow afternoon ;( ? Are the e-brake shoes stuck? Seems odd it would move as far as it does. I sure hope the differential hasn't come apart, or something... What am I to do?? |
Wow - hey, amazing what one can overlook.
Good thing I wasn't able to 'get a run' at it! So, shorter bolts, and hopefully these ones will come out with the threads still intact! G |
