Glow plugs...anybody know the secret to bypassing the ingnition switch?
Old Oct 19, 2005 | 10:17 AM
rcgiddings's Avatar
Default Glow plugs...anybody know the secret to bypassing the ingnition switch?
1978 240D
I think my problem is in the ignition switch. Sometimes the glow plugs work and sometimes not. Sometime I rap the steering wheel and they come on. I went and bought a 15 amp push button switch yesterday, but I would sure like some directions on which wire to feed raw power and install the switch.
Old Oct 19, 2005 | 12:59 PM
Kajtek1's Avatar
Default RE: Glow plugs...anybody know the secret to bypassing the ingnition switch?
Push switch gives you little knowledge about required timing for glow plugs. Those plugs can take a minute of power, but at some time they'll burn. I would rather spend some time and restore original wiring.
If you really want to install the push switch, the easiest way I see is come with the wires from the relay, that is easily accessible under the hood.
Did you make sure all the fuses are copper? Just a tough.
Old Oct 19, 2005 | 10:16 PM
dondas's Avatar
If you were to use a switch to bypass the unit, You will need at least a 40Amp switch, and some pretty thick wire. Or else keep a fire extinguisher handy
GA Cronje
Jun 14, 2010 01:33 AM
jaredroth
Jun 30, 2009 05:05 PM
jeffb
Jan 2, 2009 08:33 PM
fly_major_fly
Nov 6, 2005 02:13 AM
daveward
Aug 26, 2005 02:35 AM
