Glow Plugs
Old Feb 17, 2009 | 03:14 PM
barrylndn's Avatar
Default Glow Plugs
The previous owner of my '74 240d did some creative by-passing of the ignition switch, which, coupled with no owners manual, leaves me not knowing where to turn the glow plugs on. I have not found a switch, or indicator light telling me I have found them - actually, the extremely rough starts tells me i haven't found them. Thoughts?
In addition, I've seen fast-glow kits to replace the old-style glow plugs. Are there some that are better than others for the w115?
Old Feb 17, 2009 | 04:24 PM
barrylndn's Avatar
Default AH
Does the Gorilla **** have a back with several pins that connect into a harness that can be removed? If so, mine dangles from underneath the dash, and there was a screwdriver left to turn it. No indication when in any position of glow plugs coming on. Just ordered 4 new ones, so we'll see if that helps.
This is what I was talking about.
Old Feb 17, 2009 | 04:28 PM
barrylndn's Avatar
Also, there is a pull **** in the middle of my dash - almost inline with the shifter, that when pulled, a light comes on inside it. when you let go, it returns to the former position, and the light is extinguished. I thought that was the glow plugs at first, but apparently not. So what is that ****'s function? Thank you for your patience!
Old Feb 17, 2009 | 04:31 PM
barrylndn's Avatar
Default Oh...and Just one more thing (-Columbo)
Forcedinduction - noticed on the bottom of your posts you also have a 240d Turbo How did you manage that?
jeffb
Jan 2, 2009 08:33 PM
rcgiddings
Oct 19, 2005 10:16 PM
teepolo
Sep 17, 2005 11:15 AM
teepolo
Jul 28, 2005 06:47 PM
Kichus
Feb 9, 2004 06:31 PM
