glow plug install in 98 e-class
Im getting a solid glow plug light telling me one or more of my plugs is bad. Aside of taking off the massive exhaust manifold to get them does any one have any tricks to make it easier?
Any other pitfalls associated with taking off the manifold?
thanks Chris
[IMG]local://upfiles/24961/D37E87A666D048C9B851A8A3BC789326.jpg[/IMG]
[IMG]local://upfiles/24961/E031F4773D7D4FFE82FE0E31160DEF4F.jpg[/IMG]
thanks Chris
RE: glow plug install in 98 e-class
the other posters have given you good advice regarding the glow plugs. I would get in a good supply of PB Blaster, and a product called Freeze-Off, which are both sold at most auto supply stores. When taking out the glow plugs, use a deep 6 sided socket, and if any resistance is encountered, use plenty of PB blaster along with Freeze-Off. Most of the time, when a plug refuses to budge, it is because of carbon buildup around the plug tip itself. Buru lists the breaking point of their plugs at around 45 N/m, so when I removed my plugs, I used a torque wrench when space allowed, and tried to stay within that amount of force. Patience is the key word here, and it took me 6 days of spraying, and moving the plugs in incremental amounts in order to get them all out in one piece. Five of my plugs were carbon bound, and without the sprays, proper tools and a lot of patience I could have met with the disaster as mentioned by Forced Induction.....Good luck!!
