fumes inside car
Old Nov 21, 2009 | 09:32 PM
motofan96j's Avatar
Default fumes inside car
FNG here. Any help greatly appreciated.
I have an '85 300sd with around 248k on the ticker and it has just started leaking a lot of exhaust through the vents. It is enough to blacken the windows and leave residue on every thing. If the outside air vents are turned off(with O button) it is ok. I think it may be leaking into trunk as well.
The rear portion of exhaust, behind resonators at inlet to muffler, fell off due to rust through and a bad hill in driveway. This was several months back, but I've been ignoring it to try to put off until I can plumb on a larger pipe frt to back. Other than this it has been running fairly well.
It is my daily driver, 67 miles round trip +, and I work seven days a week. I'm coming up on a four day weekend so any hints of what to look for or parts to source ahead would help a lot.
Thank you for your time,
Dan
Old Nov 22, 2009 | 10:23 AM
cycleboy's Avatar
To add some clarification to FI's statement: not only is the flex tube the weak point, it is located right in front of an air inlet for the interior.
Old Nov 26, 2009 | 10:34 PM
motofan96j's Avatar
You are dead on. I checked it last night and it is the culprit.
Any suggestions for a fix without replacing full exhaust?
Old Nov 28, 2009 | 11:31 PM
motofan96j's Avatar
Thanks for the help. Do you have any suggestions for parts sourcing? So far I've done several parts searches and have seen a wide range in price and actual availability. I'm looking now for an oil pan for my td and have been quoted everything from $235 to $465. I've also waited three weeks for parts just to be told they were on back order then be offered used parts.
btglover
Oct 16, 2008 12:55 AM
Fixit
May 17, 2008 09:14 PM
toopeh
Feb 15, 2008 06:45 AM
paul060266
Feb 3, 2008 06:01 PM
hoytheld
Jul 5, 2006 06:06 PM
