Fuel Leak
I was checking my oil a few minutes ago while filling up at a gas station and noticed a small puddle of fuel that had collected in the front head cover bolt. The fuel hoses from the fuel filter to the glow plug are wet with fuel. I turned the car on and it looks like fuel is leaking from the top of the front glow plug? Help diagnosing!
Thanks for the correction. It looks like the leak is coming from the top of the injector not the hoses. If it is coming from the top of the injector, will I need a new one?
Since you're not sure, you would be wise (and it's certainly more economical) to go ahead and replace the fuel hose as a prophylactic measure. Worse comes to worse, you've changed out some line that will go bad eventually anyway and eliminated one possible source of the leak.
Oh, not dangerous at all! Combustible material, hot engine, it's all good. You don't happen to bathe with your radio plugged in and sitting on the edge of the tub too, do you?
In all seriousness, it is not likely that the leaking fuel will ignite; however, it just ain't smart.
Took the car into the mechanic this morning. I'd love to save money and tinker with this myself but I need the car for work. The mechanic is really cool. He sourced the problem to the steel line that connects to the top of the fuel injector. Replaced the line with a used part from a spare engine and the problem is solved! Took 15 minutes tops. Next time I change the oil I'll replace the rubber fuel lines around the injectors.
