Freakin hood won't latch closed '84 300SD
Old May 24, 2008 | 08:03 PM
greaser's Avatar
Default Freakin hood won't latch closed '84 300SD
Hi all. Can't get the stupid hood to close all the way on this one. It goes past the safety latches but won't catch and hold so as to be flush with the fenders.
Here's what I've tried:
*Adjusted the threaded cable adjuster in the engine compartment (driver side 10" behind headlight). I've moved this thing back and forth in lots of possible combinations and no change - except for the hand release by the driver door becoming tighter/looser.
* Adjusted up/down and finally removed the two hood bumpers on the rail above the headlights. No change.
*Removed from the hood one of the the u shaped things that goes into the latch/housing. I pushed the thing in manually watched it go inside the latch. Using all possible variations of angles and force, could not get the thing to latch or even act as though it was thinking about latching. The secondary safety latch works, but not the primary one that is activated by the car's interior release handle.
Can't find this answer in other threads. Thanks for your help and have a great long weekend .
Old May 25, 2008 | 11:47 AM
greaser's Avatar
Default RE: Freakin hood won't latch closed '84 300SD
Of course that makes sense, but I've thoroughly checked all those things. And again, I removed a hood catch (u-shaped things) and pushed it into both spring pits manually. They won't latch.
Robert Finden
Jul 16, 2010 04:09 AM
urs4sell
Aug 19, 2007 12:04 AM
ecodiesel
Mar 20, 2007 05:02 PM
g1golo
Jul 13, 2006 01:41 AM
jtong
Dec 28, 2004 04:22 PM
