Expansion Tank Replacement
Expansion tank plug kit.
What is the proper install order? Slide O Ring into plug shaft, Insert plug shaft into expansion tank then insert E Clip atop it? thanks and cheers. |
What is this expansion tank plug kit you are speaking of? I also have an 85 300TD. Thanks.
