erratic turbo behaviour or automatic transmission sticking ? 1988, 300D
Old Aug 17, 2011 | 05:46 PM
iloveoldmercs's Avatar
Default erratic turbo behaviour or automatic transmission sticking ? 1988, 300D
hello, I recently bought a 1988, 300D turbo with 350k kilometers, it looks great and runs very well but has a few issues, for ex; sometimes it seems as if the turbo is stuck on, at slow speeds it revs high and the turbo kicks in when i press the gas pedal and it doesn't change gear, if i press the pedal a little bit nothing happens. The temperature raises fast to the point that i have to pull over and stop the car, after restarting the problem is gone. I topped up the automatic tranny fluid but may have slightly over filled it because i can't seem to get an accurate reading from the dip stick. I noticed it was leaking tranny fluid after i topped it up. Could this be a tranny problem or perhaps a turbo problem ? please help, thanks.
Old Aug 19, 2011 | 01:29 PM
BenzDieselTuner's Avatar
why wont the dipstick let u measure it?? when its nice and hot and idling??
these can be sensitive to overfilling....my 85 sure is.....
Old Aug 20, 2011 | 03:01 AM
I tried checking the tranny fluid while its hot and idlying on level ground but there is patchy fluid all up the dipstick and very difficult to get an accurate reading, also the fluid is almost transparent not pink like it is in the bottle and when it leaks onto the driveway.
ashton101
Mercedes A Class
Jan 15, 2011 09:43 AM
djgonzo
Apr 22, 2009 05:19 PM
gary_nada
Oct 12, 2007 05:51 PM
bacullen
Aug 17, 2005 04:30 PM
honeybee
Oct 29, 2004 02:24 PM
