E300 td big engine issue!!! URGENT
Old Jul 16, 2012 | 02:53 PM
meanfazer's Avatar
Default E300 td big engine issue!!! URGENT
Hello....need to pick some tech's brains please,got an e300 w210 with the 3.0 diesel lump....had a small crack appear around the bolt boss in the timing chain cover where the belt tensioner bolts on ,that has now turned into a huge piece of aluminium removing its self and the belt tensioner falling off with oil cascading every where......i plan to remove the cover and repair /replace but was looking for some removal advice.....does the cover come out without removing the head and sump or what???? just looking for some pointers before i go in blind!!!! any help would be appreciated,thanks J
Old Jul 18, 2012 | 06:03 AM
meanfazer's Avatar
Default useful info
got the broken cover off.....merc part number R602 015 01 01.......merc want £157 + VAT ,it turns out it is exactly the same part number as fitted to the sprinter 2.9 5 cylinder engine, just got one from the dreaded flea bay for £50........maybe of some help to anyone in the future...absolutely no 606 engines in bits anywhere. ;o)
Old Jul 23, 2012 | 04:43 AM
meanfazer's Avatar
Smile e300 cover
all done now......BUT!,,,,, the casing from the sprinter had 1 difference even though the numbers on it were exactly the same!......the oil feed hole for the vacume pump was not there! ,nor was the detail in the rear of the casing where it takes its feed from the engine,luckily being an engineer and having a bridgeport milling machine I managed to transfer the machining details over onto the sprinter part and it works........big smiles
meanfazer
Jul 23, 2012 04:40 AM
meanfazer
Jul 16, 2012 02:58 PM
nbrock_85
Jun 7, 2010 06:01 PM
maserati
May 1, 2009 11:42 AM
yansa
Dec 27, 2007 01:03 PM
