Dash lights
RE: Dash lights
Joe, my 77 300D has the same problem. The stock bulbs are dim. I don't remember the replacment number, but you can get a brighter bulb. The downside is that you have to remove the insturment cluster to replace them. I'll look in my old notes and see if I can find the Osram bulb number.
RE: Dash lights
Joe,
Here are a couple of links about replacment bulbs.
It is not recomended that you use a 5watt bulb because of the damage (melting plastic) caused by the hotter bulb.
I think I am going to look into the LED option ( almost no heat ).
Wayne
This one has dash removal information too:
http://www.mercedesshop.com/Wikka/W124InstCluster
https://mercedesforum.com/m_75162/tm.htm
Wayne
