-   Diesel Discussions (https://mercedesforum.com/forum/diesel-discussions-33/)
-   -   compression on a 240D (https://mercedesforum.com/forum/diesel-discussions-33/compression-240d-3379/)
gavinbr Jan 5, 2005 09:04 PM
hello,
i have low compression on my 1982 240D with 250K miles
how do you tell which is the problem, valves or rings.
any suggestions would be appreciated
brian
pberku Jan 5, 2005 10:54 PM
RE: compression on a 240D
Put about a teaspoon of oil into each cylinder (one at-a-time), and measure the compression again. If now, it significantly increased, than its your piston rings. If no change, than most likely its your valves, or a valve adjustment is required.
Phil
