Catalytic converter
i have a 1998 e300d
with a catalytic converter that has 2 holes in it the size of quarters. Would it be ok to take the care to a muffler shop and have them replace it or should i buy one from ebay or certified mercedes online dealer ? |
Originally Posted by ForcedInduction
(Post 129921)
Put a straight pipe in its place.
(Post 130011)
So. You'll get much better economy, you'll get more power, your engine will run cooler and it will live longer.
what is a good aftermarket catalytic converter for my non turbo e300d 1998
(Post 130025)
False. Nearly all states that test diesel emissions only inspect for smoke opacity. The only state it would be an issue with is the CARB Nazis of Kalifornia.
FYI, in California there is no bi-annual smog test/inspection for diesel vehicles (car and pickup trucks, at least) as there is for gasoline powered vehicles. And since there is no safety inspection either, no one would really know if you replaced a cat. conv. with a straight pipe. From the CA DMV web site: Does my vehicle qualify for a smog exemption? Smog inspections are required unless your vehicle is: * Hybrid * 1975 year model or older * Diesel powered * Electric * Natural gas powered and has a Gross Vehicle Weight rating of 14,001 lbs. or more. * Motorcycle * Trailer BTW, thanks for all your great technical insight and forum participation. Regards, --Jim Jim Jim |
cat converter
You are absolutely right, diesels are smog exemt in california, so no one will no if you've modified you car. I removed mine, because it started to rattle, and rather than buy a new one, I put in a straight pipe. It was a tiny bit louder, but the improvement in performance was dramatic; probably because my old cat was clogged. There was a slight improvement in mileage too.
This correct Sue, I had my cat converter removed last year, my car (210 E300) run faster, better MPG, cooler, a lot less smoke, close to 20 lbs lighter but a few decibels louder than normal. I am in Ca. and diesel engines does not require inspection.
