Cap nut & Lock nut (counternut)
Old Sep 15, 2009 | 12:46 AM
raffo's Avatar
Default Cap nut & Lock nut (counternut)
How do you replace the Cap nut and Lock nut for the 617?
Do you remove the spring that holds the rocker arm and everything will come loose?
Old Sep 15, 2009 | 12:43 PM
raffo's Avatar
Thanks. Are there any other tips, tricks and special procedure before removing 1 rocker arm?
Checked and adjusted valves 2 months ago and found that the lock nut (counternut) intake valve, cyl. 5 was rounded off. Cam and other nuts are great, except for that one lock nut.
daisy_trippin
Mercedes A Class
Jul 2, 2009 08:13 AM
kacyk
Nov 23, 2005 03:40 PM
jnash
Jun 15, 2005 11:09 AM
dorian
Apr 23, 2005 12:49 PM
dorian
Apr 23, 2005 12:47 PM
