c220cdi - power loss problem
Old May 2, 2010 | 05:28 AM
Zed's Avatar
Zed
Default c220cdi - power loss problem
Morning All,
I purchased a c220cdi, 2002, auto, estate a few days ago and have power loss issue with it.
When I do a kick down a message appears "EL, power control, please visit workshop!" and the EPC light shows beneath it. Then goes into "limp mode".
I have disconnected the MAF sensor but the problem remains the same.
If I switch the engine off and restart it the malfunction disappears. Then when I'm driving it normally it it seems to be ok, going up a hill can be a bit of a struggle and it doesn't seem to go above 85mph but no malfunction is showing.
Can anybody help please?
Old May 2, 2010 | 08:06 AM
cab262's Avatar
Default Same Problem
Hi Zed I am having exactly the same problem as you "same vehicle", this is what i have tried ,,
Can someone tell me if the egr should hold a vacuum on a 02 C220 CDI when operated via a hand vacuum pump, I am trying to sort out an ongoing problem with this car that wont rev over 3000 rpm. the codes from a star machine were P1403 P1470, Have changed the MAF and just stripped down the egr " Loads of Crap in there". the engine note does change if I hand Vac the egr and it is definitely moving, but its not holding a vacuum
Thanks Paul
Ps if i turn of ignition and restart the problem goes away for a minute or two then returns
Old Sep 29, 2010 | 06:31 AM
l4hlsn's Avatar
Default same problem larger engine
i have the same power loss problem on a g400
it starts fine then i accelerate it and it goes into limp mode no more than 2000 rpm and 80 km/hr. i start stop the engine problem goes away for a couple of minutes and then back to the same .
took it to dealer they changed the epc module that was expensive very expensive no codes on the dashboard no malfunctions but the problem persists
any help?
Zed
May 2, 2010 05:24 AM
MartinDahl
Mar 24, 2007 08:26 AM
GERMAN MAD
Oct 8, 2006 09:02 AM
rtrimarchi
Apr 26, 2006 05:32 PM
jomare
Jul 7, 2005 10:58 PM
