Before I take apart the dash
Old Mar 11, 2008 | 06:25 PM
treadstone71's Avatar
Default Before I take apart the dash
Presently my 190D will not turn off with the key. Everything that I've read and been told says its a vaccum issue. I checked the vaccum up to the fire wall and the vaccum is about 22. I'm guessing the next step is to take apart the dashboard to get at the ignition. One thing I did notice is a little oil leak around the ignition. The leak, small as it is, is coming from where the two halfs of the ignition meet. Could this be my problem?
Old Mar 11, 2008 | 06:41 PM
Mr.47's Avatar
Default RE: Before I take apart the dash
Before you remove your dash check for cracked vaccume hose in the engine bay i dont know where is it located on 190D butjust check for thoseoldbrittle cracked hose, trust me its will save you a ton of time and hassle
Old Mar 11, 2008 | 09:02 PM
I checked the lines all the way to the fire wall and their was good vaccum. The leak has to be between the firewall and the ignition.
Old Mar 12, 2008 | 03:51 PM
AMGMercedes's Avatar
Ditto, just remove the panel, it uses 3 screws. You will hate life if you remove the dash becauseit will take at least 2 hours and involve like a thousand wires on the back of that instrument panel. Trust me!
Old Mar 12, 2008 | 06:31 PM
I have the panel removed but can't really get to the vaccum tubes. Its a mess up there. Is the ignition lock mounted to the steering wheel for stability or is there some function going on between them. If I could just get the ignition lock free from the steering wheel I could work on it. This is a pain.
RyanB86
Feb 15, 2010 06:35 PM
rickcr
Apr 9, 2008 12:33 AM
fmurch
Jun 3, 2007 09:38 AM
fmurch
Jun 2, 2007 11:38 PM
