85 190D Brakes & gen. ques...
Here we go...
Just purchased an 85 190d w/ 230k mi. The brakes are real spongy, and seem to work at the floor. What could be the problem? The thing won't shut off- I have to go under the hood and activate the cut off lever! Looking at the motor, the left side of the valve cover has a small (pinhole) in it that exhaust gas leaves from...Is this normal? Also there is {no} power when going up a steep grade... Help, suggestions, etc will be greatly appreciated... Thanks all,Bo |
RE: 85 190D Brakes & gen. ques...
brake master cylinder or....
the piston of the vacuum pump is kaputz. repair kit is 601 230 01 65 (not confirmed unless you give me your VIN). |
check vacuum line check valve also (black/white color).
