84' 300DT half shaft replacement problems
Old Apr 17, 2009 | 07:48 AM
Big_Al's Avatar
Default 84' 300DT half shaft replacement problems
A few months back I noticed the boot on the drivers side, rear CV joint was split and the axle was making a swooshing sound especially while accelerating. The swooshing noise had been going on for months and the rear end would also shake a bit during acceleration.
Half Shaft replacement:
Took off tire, caliper, unbolted shaft from center of hub, drained differential, *lowered and opened differential, removed c-clip, supported wheel and differential with separate jacks, raised diff, shaft came out of hub, pulled shaft from diff.
*While initially lowering the differential I unbolted it until it fell… doh! It took me a few minutes to move the jack into place and support it.
During installation of the new half shaft the c-clip grove, inside the differential, was not coming through enough to push the c-clip on. At this point I decided to take off the spacer ring from the outside of the differential housing, to give me enough room.
I hoped the new half shaft that I installed would solve both problems, the swooshing is gone but the shaking has become worse and when the car has been sitting for a while and I drive a few feet down a perfectly smooth road, I can feel the rear end lift and fall as if one of my tires was slightly egg shaped.
My questions are:
Should I have removed the spacer?
If not, what should I have done to push the shaft through enough to put the clip on?
Could I have ruined this or the other (passenger side) half shaft?
How do I diagnose which shaft is causing this rise and fall of the rear end?
Thanks in advance!
-Al
kevlex4
Feb 5, 2016 10:16 AM
benzyman
Sep 10, 2010 10:01 AM
davecut
Mar 15, 2008 02:04 PM
trailrock
Apr 15, 2007 07:13 PM
BlackWolf
Jul 10, 2006 07:46 PM
