84 190d auto transmission
Old Mar 18, 2007 | 08:14 PM
tom4190's Avatar
Default 84 190d auto transmission
Just purchased a 1984190d with auto tranny... when in D it will go to1st gear and then slip to nothing, no go... if i manually put it in 2 it will shift to 2nd gear.... if I put into 3 back to nothing.... back to D is back to 1st gear... the car has less then 200k and seems to run strong in 1st and 2nd gear... just won't shift on it's own.... any suggestions... Thanks, Tom
Old Mar 18, 2007 | 11:47 PM
otm646's Avatar
Default RE: 84 190d auto transmission
do the basics first. check the trans fluid color and level. if the trans is slipping all the time it my be due to low fluid level. also look underneath for and major fluid leaks.it that all checks out ok find a good transmission shop or another similar 190 with a working trans.
Old Mar 20, 2007 | 11:45 AM
AMGMercedes's Avatar
Guessing it could be a vaccum problem also preventing gear shifting, but would assume a low tranny fluid level.
Old Mar 22, 2007 | 04:44 PM
cyberbackpacker's Avatar
How much do you think a tranny rebuild would cost? Also, how feasible/difficult/cost of converting the 4spd auto to a manual tranny?
Old Mar 22, 2007 | 11:07 PM
Probably about 2 grand or less. Conversion isn't that difficult, search 190revolution.net for the best answer
Old Mar 24, 2007 | 06:51 PM
Thanks for the lead on the link and info.
Serenity
Apr 9, 2015 08:55 PM
bigblockchev1
Jan 9, 2009 07:29 PM
1Bad190D
Nov 15, 2008 08:31 AM
roylog
Mar 21, 2007 10:40 PM
roylog
Mar 21, 2007 10:39 PM
