83 300sd Mono valve check
I think my mono valve (heater control) is bad. I have intermittent heat, it will produce good heat then start blowing cold air. I am fairly certain the aux pump is working, I can hear it running.
How do I check the mono valve? Also, does the mono valve have 12VDC supplied continously when calling for heat? |
| All times are GMT -5. The time now is 07:19 AM. |
