81 240d cranks over but won't catch.
I'm a new owner of an 81 240d. Since buying this car I have changed the glow plugs and had the valves adjusted. After having those things done the car has started and run quite well. However, it has suddenly quite starting. It will crank strongly but won't start. It won't even try to start. It just cranks. Any thoughts out there? Any help would be greatly appreciated.
Originally Posted by ForcedInduction
(Post 170661)
Start with replacing the fuel filters. Make sure fuel flows through the lines when you pump the primer and that the primer does not leak any fuel when manually pumping.
(Post 170661)
Are you sure your fuel gauge is accurate? Toss in say three gallons after changing or tightening down real hard on the primer pump, best to change pump.
(Post 170691)
Replace the primer. Fuel leaking out means air can leak in.
The new version does not have a screw-out handle. |
Originally Posted by pbsled
(Post 170693)
