'76 240d Smokes only on decel
Old Apr 22, 2008 | 02:26 PM
  #11
danpayton's Avatar
Default RE: '76 240d Smokes only on decel
Ok... That seems to be a guide for adjusting linkages... I went over it, and everything looks ok on the car...
but for some reason there just isnt a strong enough venturi effect coming thru the throttle body to generate enough vacuum for the IP control line.
there isnt anything clogging the venturi tube at all... and ive checked the tube for leaks... it holds vacuum just fine.
DoI need a new throttle body? or is there a calibration adjustment on the IP for the amount of vacuum in the control line / fuel output at idle?
thanks
-Dan
Old Apr 23, 2008 | 06:45 PM
  #12
danpayton's Avatar
So i replaced the throttle body.... same problem.
I took it in and spoke with a guy at a local shop.... he said there is goat skin in the IP that can wear out...?!?!? (good 'ol germans)
so thats gotta be it. Need to put in another IP i guess.
can this be done without disturbing the timing chain?
thanks!
-Dan
kamel
Aug 18, 2010 10:12 AM
Paradocs
Jun 14, 2010 09:01 AM
ddarnell
Feb 6, 2009 10:55 PM
el baby benz
Mar 28, 2008 05:33 PM
bucketoval
Jun 23, 2007 10:06 AM
