308 CDI 2.2 won't start - hot or cold
Hi all!
my Sprinter CDI 308 2.2 was running fine until one day I simply turn the key off. When tried to start it again just 10 seconds after this it couldn't start. I crank it til the battery went flat but no luck. After this someone gave me the idea of spaying some easy start into the air pipe and...miracle - it started straight away. I drove back home with no problems but as soon as I turned the key off and tried to start it, it would get going without easystart. I borrowed a carsoft interface to check the ECU and found out that there ware 5 errors stored on it. I erased them and tried to start it but the problem remained. Then a changed the fuel filter together with the water sensor (the one that goes underneath the filter), stack the pipe which feeds the filter in a bottle full of fuel (just in case there something wrong along the system from the tank to the filter) but the problem was still there. Then removed the plastic cover to expose the common rai, undid the pipe which feeds it, cranked the engine and found out that the pipe is bleeding. After that I undid each one of the 4 pipes feeding the injectors but found out that there is fuel there as well. The engine still sounds great but won't start without easystart. No errors are stored on the ECU neither. Have anyone had similar problem and do you guys have any suggestions of what could have caused it?
ORIGINAL: amberolaman
does this model have glow plugs?
[align=center][/align]
check the resistance on the glow plugs and check for voltage being delivered to them when you are in start mode. if it fires easily and runs smoothly when starting with ether, it would almost have to be something with the glow plug system (my experience is with older stuff, so you can take this with a grain of salt)
by the way, ether is bad stuff I wouldn't use it, could hurt your engine
[align=left] [/align]
Turned to be the o rings in the pressure regulator at the end of the high pressure fuel rail. On starter motor the high pressure pump can not build up enough pressure/ volume to overcome that lossed through leaking o rings. With the engine running on easy start the pump turns over fast enoung to pressurise the fuel rail and injectors.
crusier888
Oct 13, 2019 04:46 PM
bluesky 2008
Apr 28, 2008 02:00 PM
prtinting
Mar 20, 2007 10:00 PM
