300D turbo diesel
Old Nov 24, 2006 | 12:40 AM
2006crisha's Avatar
Default 300D turbo diesel
I have a 1984 300D turbo diesel and I am having trouble with it starting in the cold weather. My glow plug light in the dash is no longer lighting up. My question is, is there a controller of some kind that powers the glow plugs?? I dont think that the glow plugs go out all at once or do they??So I am hesitant to replace them at this time. Once the car is started it runs great. I have to keep it plugged in all the time now, and it will start most times but not all. Our temps here in Wa state are around 30F to 55F. I have checked the fuses and they are all good. any ideas thanks
Old Nov 24, 2006 | 12:45 PM
AMGMercedes's Avatar
Default RE: 300D turbo diesel
I'm not a mechanic, so don't rush out and buy stuff, but I would suspect the problem is the glowplugs. It's happened frequently here lately.
Old Nov 24, 2006 | 01:18 PM
Charles Munn's Avatar
ORIGINAL: 2006crisha
I had the same problem on my 1982 300D T. It was a bad relay. The relay is located under the hood in a small black box on the drivers side, inner fender.
Old Dec 23, 2006 | 10:16 PM
Benz Guy's Avatar
Hey dude. Sounds like one or more of your glow plugs are bad. What year is the car? Have the glow plugs ever been replaced. There is a glow plug relay that you can check to see if one or more is bad depending on the ohms resistance level.Let me know if you need more help.
Dave
Old Dec 23, 2006 | 10:31 PM
Benz Guy's Avatar
check this thread too with the problems and solution for my 300D
https://mercedesforum.com/m_11606/tm.htm
Old Mar 20, 2007 | 11:45 PM
juggernaut's Avatar
i threw 5 new glow plugs in my diesel, and its good for 0 degree starts. jus thought i'd let ya know what it should be able to do.
Old Mar 23, 2007 | 10:46 PM
guage's Avatar
What brand plugs did you put in?
Old Mar 23, 2007 | 11:18 PM
juggernaut's Avatar
to be honest, i have no clue.. i ordered them from napa..
Old Mar 26, 2007 | 05:48 PM
  #9
trailrock's Avatar
you are going to wanto put in the upgraded Pencil syle plugs. generally they are made by bosch. The other kind (loop style) is outdated, in efficient and has other problems. if you have the loop stlyle in your car you will have to remove the groundwire from the last plug when you put the new pencil style plugs in.
let me know how it goes. my car too is having problems starting. Also, might I warn you that replacing the plugs is very difficult because they are generally on so tight and they can be tough to get to with a 12mm wrench. there is not enough room for most ratchets, and with each wrench crank you can only go about an inch. it can be rather frusterating.
good luck
mercedesdieselpetr
Apr 1, 2015 09:13 PM
geoff.doctor
Jul 12, 2008 10:54 AM
turbiodiesel
Sep 16, 2005 06:36 PM
lukapsu
Dec 7, 2004 02:22 PM
300dforsale
Oct 18, 2004 02:19 PM
