300D no head lights
ive checked the fuses, and the lights arent burnt out.
It has to be a relay, or a hook up some where. The high beam light is also out, everything thing else works, parking light, and blinkers Any help would be greatly appreciated, |
Get a continuity tester and start testing connections from the fuse box forward. There's a junction on the sub-harness from the lights to the main harness. That would be a good place to look.
i checked the light switch, and the power cable is all melted, i think thats what is. 100$ part though. I'm also going to check all connections before i make the purchase.
Thanks for the help guys |
replaced the light switch, really easy, just went to a junkyard, cut it out, and put it in, works good as new.
thanks for the help : _) |
