300 D - cause for concern?
Old May 22, 2008 | 07:40 AM
rhlbenz's Avatar
Default 300 D - cause for concern?
greetings,
i have a 92 300 D 2.5T w/ 205K. quite enjoy the ride but a problem has arisen which i hope someone can give clarity to.
the basic problem is that the oil pressure is very low. with the a/c on, it barely gets above the o mark. without the a/c it hovers between 0 and 1K RPMs.
i was having problems with the ABS light remaining on after starting, and after research replaced the OPV relay, which took care of the ABS problem, but may have affected the oil pressure at idle.
any ideas?
thanks in advance.
Old May 22, 2008 | 07:59 AM
rhlbenz's Avatar
Default RE: 300 D - cause for concern?
as an additional note - the oil pressure achieves 3 bars when accelerating or at highway speeds.
Old May 22, 2008 | 06:38 PM
Drrty240D's Avatar
Sounds like a real, honest to goodness low oil pressure situation. Only way to know for sure is to attach an external oil pressure gauge to the engine and compare results. Good luck.
Old May 22, 2008 | 07:06 PM
rhlbenz's Avatar
interestingly, i didn't notice this problem 'till like i said, began using the a/c, which means the temps have been in the high 80s. today, however, it was in the 60s, and the oil pressure was back up above 1 bar.
how should weather affect this?
thanks again
Old May 23, 2008 | 06:30 AM
Drrty240D's Avatar
When the A/C compressor is running with the engine at idle it creates more work for the engine and therefore lowers the oil pressure. It is a combination of the parasitic drain through the belt drive system plus the effect of reducing the RPM by a small amount when the compressor is on. Higheroutside temps equate to thinner oil and slightly higher engine operating temps.You'll achieve normal engine operating temp quicker on an 80 degree day versus a 60 degree day.
Old May 23, 2008 | 04:25 PM
lwbrewer's Avatar
what weight oil are you running and a manual gauge to double check the electric one 87 300D
Old May 24, 2008 | 08:07 AM
Drrty240D's Avatar
I run Delvac or Rotella 15W-40. You can run a higher viscosity oil in an engine that is having internal problems as a temporary measure to increasepressure. Obviously, anything wrong mechanically will need to be fixed sooner rather than later or you risk puking the entire engine. You can trya synthetic 5W-50 like Mobil-1 or 0W-50 Eneos or even an aircraft/motorcycle grade 70W oil.
You'll neverfind straight 70W in the auto parts store;it will probably need to be ordered online or obtained from a specialty store. Look for Pennzoil, Ultima or Klotz. Your local Harley-Davidson store (?) may have some. Running a heavy straight weight oilis risky due to the high viscosity at startup. If the outside temp in your area is lower than 65 degrees Fahrenheit I wouldn't run the 70W.
I don't have an external oil pressure gauge for diagnostics, but you can buy one at the local auto parts store. Not sure where an external oilpressure connectionwould be on a 1987 300D- anyone know?
Old May 27, 2008 | 03:07 PM
Drrty240D's Avatar
So, to check oil pressure using a manual gauge (1) temporarily remove the electric sending unit from the engine (2)thread the gauge (or fitting w/hose to gauge) into engine (3)start engine to check oil pressure.
ml_owner
Dec 3, 2007 04:46 PM
brit1967
Aug 21, 2007 07:28 AM
gearheadHD
Jun 19, 2007 11:10 PM
busa
Jun 25, 2006 09:17 PM
mbfaster
Feb 1, 2005 11:28 PM
