3 issues identified by mechanic. Which one to tackle first?
Old Jun 6, 2008 | 06:24 PM
Scuddog's Avatar
Default 3 issues identified by mechanic. Which one to tackle first?
Hello! I just took my newly acquired 1982 240D with 313K on the clock in for a used car inspection. The mechanic said that the following are requiring attention:
- left ball joint
- repack wheel bearings
- differential pinion seal
Which one of these is the most important and which one is the least? This is some $$ to spend and my economic stimulus money was spent on booze and women. Help! Ha!![8D]
Old Jun 7, 2008 | 09:49 AM
mb124d's Avatar
Default RE: 3 issues identified by mechanic. Which one to tackle first?
MHO: ball joints, they will wear out your tires as the alignment gets worse, and eventually fail collapsing the suspension.
The repack you can do yourself.
The final drive, usually a small leak, just add it to yourlist of thingsto check at each oil change (along with pwr. steering fluid level).
You spent your stimulus check wisely....
sidviciousx's Avatar
the wheel bearing and ball joint should be done together.
Old Jun 9, 2008 | 08:32 PM
Scuddog's Avatar
Are there any online resources to learn from on the bearing repacking? I have a repair manual that came with the car.. similar to a Chilton's. Any advice would help here as the repair manual isn't exactly 100% on target. Any pitfalls to avoid etc???
Old Jun 11, 2008 | 07:28 PM
Scuddog's Avatar
Forced Induction... this is great! What a link! Time to roll up my sleeves!!!
PelicanParts.com
Apr 16, 2013 12:19 PM
PelicanParts.com
Apr 10, 2013 03:36 PM
benzguy
Oct 23, 2010 03:33 PM
Wedowee
Jul 9, 2010 09:12 PM
turbosteve
Apr 9, 2005 08:00 PM
