2008 e320
I have a 2008 E320. The Wastegate control is not working properly. I have already disconnected the arm and made sure the wastegate does not stick. Every once in a while the Wastegate control will not work. I shut off the car and it resets and then works for a while.
What should I check? |
Did you pull any codes off the DTC?
