1985 300D Turbodiesel Trouble... Transmission Adjustment Needed?
To put it quick and simple, my car won't go over 60mph.
I've tried everything, Transmission checked, flushed, and found to be in perfect working order. Vaccuum lines checked. OK Drivetrain checked. Brakes were applied slightly at all times, fixed. I've played around with that adjustment for the little cable coming off of the throttle linkage on top of the engine, and have had a little luck, but it is still nothing like when I first got the car. Any help would be greatly appreciated. |
RE: 1985 300D Turbodiesel Trouble... Transmission Adjustment Needed?
What RPM range are you in when it's at 60mph?
IfRPM's arenot very high or are average, you need a new fuel filter. This has happened to me, the exact same thing at 60mph. If your car is reving and the RPM's are high at 60, then yes, you need a tranny adjustment which can be $$$ versus a fuel filter. |
I forgot to mention, it is also surging. Is the fuel filter still a possibility?
Whenit gets to60mph, your car slows down, picks up speed, then does the same thing over and over? It's an odd feeling. I'm assuming it isn't really a mechanical jerking of gears, more similar to running out of gas. It's most likely the fuel filter, that also happened to me when the fuel filter needed replaced.
When's the last time you changed it along with the oil filter? |
Ok, bought the primary fuel filter tonight on the way home. The shop I went to didn't have the secondary fuel filter. I will buy the secondary filter tomorrow and install both, will post the results...
ORIGINAL: jwoulf Ok, bought the primary fuel filter tonight on the way home. The shop I went to didn't have the secondary fuel filter. I will buy the secondary filter tomorrow and install both, will post the results... Best wishes, charlie |
Tweaked some of the transmission adjustments, installed both new fuel filters. Car is now performing like new.
Thanks for all the advice. |
