1981 300CD oil ine replacement
I have a 1981 300cd non turbo and am trying to figure out how I can remove the top oil line without removing everything else in the car.
I have the lower line out. I have the motor mount out. I have the radiator out. I have the oil cooler out. I have the lines disconnected. I have the motor jacked up a couple of inches off the normal mount position. Do I need to pull the brace that attached the block to the motor mount? Is there a trick? I could cut it, but I still need to get a new line back in there! Thanks! |
Dieselgiant says "out the back"
http://dieselgiant.com/oilcoolerlinereplacementl.htm I guess I will hit it again tomorrow with renewed enthusiasm and patience and see fi I can get them out... |
