1979 300 turbo diesel
1979 300 turbo diesel HELP PLEASE
Hi all new here well few questions hope I'm posting in the right section. I might buy a 79 300sd off my buddy for 500 bucks no rust very clean new glow plugs filters and pump. Only problem is on his way home from school she shut off and now sounds like rod knock. I want to say fried piston cuz it has no oil.
I'm good with motors and building but my main question is where can I get pistons and stuff for these cars ?
Thank you
Ryan
Thank you
Ryan
When it comes to rebuilding an Engine you won't know what you need till you take it apart and examine it.
Turbo Diesel Pistons are extremely hard to find and could be around $450 each; that is right Each if you could locate a source of them.
The replaceable Cylinder Liners are relatively Cheap but need to be bored to the New Pistons.
If you opt to buy a used Engine try to buy one in a Car with a bad Body that you can test Drive. A lot of People buying an Engine sitting on a Pallet out of the Car have bought themselves a used worn out Engine or even a ruined one.
Note: The Turbo Diesel Pistons are different from the Non-turbo ones as is a lot of the Engine itself.
The crankshaft and Flywheel are Balanced together.
But, that is bits and pieces of what I remember from what I have read on the Forums.
Another Note: It is cheaper to check your Oil before you start an Engine or drive a Car you have never driven before.
Thank you
Ryan
Thank you
Ryan
hayes2325
04-13-2006 04:58 AM
hayes2325
02-25-2006 08:14 PM
