1972 220d fuel gauge problem
Old Dec 5, 2006 | 10:36 AM
96impala's Avatar
Default 1972 220d fuel gauge problem
i recently installed a subwoofer in my trunk, and shortly thereafter my fuel gage began to work intermitantly and finally quit altogether. Do you guys think it could be an electrical problem maybe (I did ground my amp right next to an exsiting ground on the drivers side of that wall between the trunk and passenger compartment), or did it (the sub) just vibrate/break something loose in the tank? Where should i start to fix the problem? this is my first benz and i have no book on it yet? as stated 1972 220d.
Old Dec 5, 2006 | 04:53 PM
carnut's Avatar
Default RE: 1972 220d fuel gauge problem
The sender for the tank is on top, left side. Look to see if the wiring connector is loose/off? Most automobile fuel gauges will go to full if disconnected and to E if shorted to ground. By quitting, do you mean it stays on E?
Old Dec 5, 2006 | 06:48 PM
96impala's Avatar
yes it stays on empty
Old Dec 9, 2006 | 08:21 PM
carnut's Avatar
Did you ever find the cause of the fuel gauge staying on E?
ddtbreakfast
Apr 21, 2008 11:34 PM
bobnickey
Feb 24, 2008 02:49 PM
bobnickey
Feb 24, 2008 02:47 PM
bobnickey
Jan 31, 2007 12:55 PM
benz_tweaker
Jan 2, 2006 07:14 PM
