1-2 Shift Feels Weird
Old Feb 9, 2010 | 12:07 PM
danpayton's Avatar
Default 1-2 Shift Feels Weird
1985 190d 2.2 NON turbo
Starting from a stop the 1-2 shift feels a little weird... not like its slipping.. but just kinda un-even, then it grabs gear 2. its not like a shift flare, but just uneven. once it grabs it seems just fine though.
when the car is cold, it shifts just fine.
I just bought this car for $900 - 305k Miles on it. Its in really good shape!
Every Automatic vehicle I own, I always put on an additional transmission cooler... Never put one on a merc Diesel though...
maybe it would help?
are the clutch packs wearing out in my tranny?
thanks!!
Old Feb 10, 2010 | 01:01 AM
danpayton's Avatar
I know that pretty much ALL cars have the "radiator" cooler... that dosent really count... I was referring to an EXTRA one. Will adjusting the Vac on the pump change the shift points.. or what exactly?
Old Feb 10, 2010 | 08:47 PM
danpayton's Avatar
Someone mentioned adjusting the Vac on the Pump.... is there a guide on this? I have not worked on one of these motors before... im used to the 5cyl ones...
what exactly does this adjustment do?
thanks!
-Dan
Old Feb 11, 2010 | 11:29 AM
danpayton's Avatar
thanks! ill give it a shot!
Like I said im used to the 5 cyl motors where the IP is easily accessable... this one seems to be buried a bit under the intake
Old Feb 21, 2010 | 02:13 PM
danpayton's Avatar
I cant get to the IP winthout taking the intake off... the only thing on there that appears to be adjustable is a black think secured with screws on the back of the IP but it has wires, not vacuum lines coming out of it... is this the adjustment?
thanks!
-Dan
Old Feb 21, 2010 | 06:25 PM
Diesel9112's Avatar
I have never seen a 190 so cannot help you with how to adjust the Vacuum Valve.
However, here is an article how vacuum and adjusting the vacuum effects your transmission.
http://www.continentalimports.com/ser_ic20242.html
cherden
Apr 26, 2007 02:07 PM
danellep
Sep 12, 2006 06:53 PM
rsmartin
Sep 2, 2006 08:26 PM
rustyclk430
Oct 15, 2005 01:39 AM
97e320
Aug 17, 2003 08:58 AM
