OEM rubber floor mats
After you get them clean (agree with using degreaser) let them dry. Then use a heat gun on the low setting. As you go over the mat you should see it come back to a dark black color. Try it on the back first to see that it does work and determine how much to heat them.
MICHAELJSL500
07-03-2008 09:40 AM
