Removing sun visor stickers
Just gently heat them and pull off? Can I use the 3M solvent for any residual stickum?
I had the same question. Did you get them off?
I recently took off the ones that show (I didn't take the ones that don't show when the visor is up) from my 2005 C230K. They just peeled off. I didn't anything special except try to be careful so I didn't end up with half a sticker on my visor!
YMMV Jim |
Wd40 can remove it and use a plastic scraper and blade to scrape it off.
you can use googone to remove the sticky glue.
I used to work in a sign shop and had to eliminate this stuff daily and used a heat gun to soften the glue and then scrape it off with an old credit card. Any one of you can use a single edged blade to scrape on the glass. We tried not to use solvents on them, it causes more troubles than it helped.
| All times are GMT -5. The time now is 09:56 AM. |
