93 300sd E2 error on radio
Your head unit has a security code that you need to punch in everytime you disconnect the battery, or remove the unit. You can get that code by going to your local MB dealership. They will need the VIN number and some require proof of ownership as well. Once you have that number, your unit should work fine.
