Vendors Special Buys See what our AUTHORIZED vendors have for you in here.
Having Issues Starting Your Mercedes? May Be A Bad Camshaft Position Sensor – Pelican
Old 09-19-2013, 10:47 AM
PelicanParts.com's Avatar
Sponsor
Default Having Issues Starting Your Mercedes? May Be A Bad Camshaft Position Sensor – Pelican
Your fuel injection computer (DME) may output a code that indicates a faulty camshaft position sensor (CPS). This important sensor tells the car’s computer where the camshaft lobes are located in relation to the combustion cycle. The DME takes the signals from the cam position sensor and crankshaft position sensor, and calculates when to fire the fuel injectors and spark plugs. If the camshaft position sensor is not operating properly, your car will run very erratically or perhaps not at all.
Pelican Parts offers camshaft position sensors for your W210 Mercedes. Click here to determine the correct part for your car.
This project should not take you more than one hour. Let us know what questions you have.
Old 12-30-2015, 12:09 PM
Aaronl522's Avatar
Default Where can I find my camshaft pos. Sensor??
I need a new one but can't locate it on 2005 c230k sedan
Old 12-31-2015, 09:55 AM
Sponsor
This image is from a 2004 C230 Sport Coupe Kompressor. Hope it helps. Sensors here if needed.
Old 12-31-2015, 12:15 PM
Aaronl522's Avatar
Default Thanks I found them
Old 12-31-2015, 12:34 PM
Sponsor
You're welcome.
PelicanParts.com
09-04-2013 01:33 PM
PelicanParts.com
06-21-2013 06:54 PM
PelicanParts.com
04-25-2013 11:24 AM
mle95
08-20-2007 07:13 PM
nukem
03-11-2007 02:18 PM
Quick Reply: Having Issues Starting Your Mercedes? May Be A Bad Camshaft Position Sensor – Pelican
