S 320 3.2 Inline 6 Timing chain
Old Dec 27, 2003 | 03:52 PM
T Lindau's Avatar
Default S 320 3.2 Inline 6 Timing chain
My car has 90k and runs fine. But I just replaced a timing chain on my Mustang 5.0. It made me think about the the MB. Does the 3.2 need to be replaced at a certain milage?I looked in the maintaince bookand it doesn't say.If I replace I guess I should do thewater pump at the same time, but this isn't listed also.Thanks. </P>
</P>
</P>
Old Dec 29, 2003 | 03:10 PM
jetforeman's Avatar
The timing chains on these engines are typically good for life, however the guide rails will crack over time and cause excessive chain slap. Usually the guide rails and tensionerdon't need attention until your mileage is well into the upper 100's range like 160k miles plus.....Also the water pump is totally seperate from the timing chain so it only needs replacement if it's leaking or the bearings go bad in it.
Junger
Mar 20, 2013 05:38 PM
Slkboi2000
Sep 5, 2006 07:01 AM
Battlecat714
Apr 18, 2006 07:54 PM
unknown
Jan 31, 2006 04:24 PM
smoother
Sep 15, 2005 10:51 PM
