S420 Heat Vent Problem
Old Dec 26, 2003 | 06:59 PM
davidfr9's Avatar
Default S420 Heat Vent Problem
I recently bought a '97 S420 with 24k miles from the Houston area. It appears that none of the floor vents are open and the center console "flow through vent" only produces cold air even with the Auto / EC activated in ambient cold temperatures. I wonder if the heat has ever been used in the car? Any help or suggestions would be most appreciated!
Old Dec 27, 2003 | 08:44 PM
Arthur's Avatar
I also recently purchased a 140 series (94) S500L. Also low km - here in Sydney (Australia). Similar climate concern. Same problem with heater. It ended up being the main heater valve/ distributor. It was frozen shut and needed to be replaced. Local cost - around A$1,000. Now works perfectly. Good luck.
takkie
May 14, 2011 12:59 AM
TXN
Dec 17, 2010 03:56 PM
deathius
Nov 21, 2008 04:08 PM
1stXmbOwner96E320
Oct 30, 2005 05:35 PM
raspro7
Jan 31, 2005 01:14 PM
