1994 S 320 OIL LEAK
Old Dec 5, 2003 | 12:26 PM
soaring's Avatar
Default 1994 S 320 OIL LEAK
I HAVE A 1994 S320 MERCEDES, I NOTICE THE OTHER DAY WHEN I WAS PARKEDI SAW SOME OIL ON THE GROUND. AFTER FURTHER INVESTGATING I NOTICEDLIKE A STREAK OFOIL COMING DOWN FROM THE TOP OF THE ENGINE WERE THE ENGINE COVER IS LOCATED. CAN SOMEONE TELL ME WHAT THE PROBLEM MIGHT BE AND HOW DO I FIX IT.<IMG height=33 src=smileys/smiley6.gif width=17 border="0">
Old Dec 5, 2003 | 01:47 PM
jetforeman's Avatar
More than likely it's the head gasket. You may want to clean the engine and look closely at the rear passenger side area where the head attaches to the block. Very common for these engines!!!
Old Dec 5, 2003 | 03:18 PM
soaring's Avatar
now that i know what the problem might be, can someone tell me how to fix it?
Old Dec 5, 2003 | 06:32 PM
jetforeman's Avatar
Irregardless of what gasket is leaking it will need to be replaced. It all depends on which one that's going to determine how deep your going to have to dig into your wallet. Head gasket replacements for your engine range anywhere from $1,100 to $1,500 depending on where you take it.</P>
orcldba8
Sep 11, 2013 11:06 AM
rx7pro
May 3, 2009 07:45 PM
mycarlile
Jan 15, 2008 10:21 PM
jdk
Jul 19, 2007 11:25 PM
aermotor
Dec 28, 2006 05:30 PM
