Engine Misfire
Old Apr 27, 2005 | 03:48 AM
vinzbenz's Avatar
Default Engine Misfire
Hey guys hope you can help? I got a check engine light on the other day on my 97 e420, got the car scanned and it says that i have a cylinder #8 misfire. Also when stoped the car does have a rough idle and bad exhaust smell? When i leave a light it all runs fine at all other speeds? I checked the basics (spark plug, wires, connections) they all seem ok.....wondering if anyone else experience this and could shed some light?
Old Apr 27, 2005 | 04:17 AM
Default RE: Engine Misfire
your VIN?
Old Apr 28, 2005 | 12:32 AM
Laterthatsameday's Avatar
pull the vac. line off the fuel regulator on the top of the engine and see if any fuel comes out of the fitting. If it does you need a fuel regulator
Old May 2, 2005 | 10:15 PM
varnmd's Avatar
Same thing just happened with my 97 E420--runs rough at idle, check engine light on, runs fairly well with acceleration. This can be caused by a misfire, when the spark arcs with the engine instead of with the plug. I found at least one spark plug boot that looked chewed up, and another plug looked much darker when I changed them. [:@] Replacement boots are available at Mercedes dealers for around $25 each. I would change the #8 boot (and any others that look bad) and I'll bet that will fix your problem. Good luck!
Old May 3, 2005 | 06:42 PM
varnmd's Avatar
Update for you--I changed a couple of the boots on my E420, still wasn't idling smooth, still with check engine light. Had diagnostics checked at garage, and one of the coils (#2 cylinder) was bad and is being replaced. Each coil costs around $120-150. So I guess it could be plug, boot, or coil that could cause a misfire and check engine warning. Rotten egg smell is from burning an incorrect fuel/air mixture in that cylinder due to firing at the wrong time in the cycle.
tewlmn97420
Nov 27, 2007 09:43 AM
tewlmn97420
Nov 26, 2007 09:54 PM
DrBobDC2005
Sep 28, 2007 10:17 PM
mlbenz
Jul 21, 2006 12:36 AM
posmaxx
Apr 7, 2004 12:10 AM
